Crank no start after tune loaded. PCM not firing cop's any ideas
Hi All,
I was loading tunes all day getting the new engine dialed in and after I loaded one, I am cranking with no spark and dumping fuel. A/F gauge read 9.8 after cranking.
I am guessing I have a problem loading tunes now.
No errors when loading. Doesn't matter which tune. No DTC's
Anyone ever have this problem?
I have seen other posts similar to this and they were wrong strategy, corrupted code, PATS error or bad PCM.
Weird thing is I get no error codes while loading tunes or DTC's.
SCT wiped their hands clean.
Even though this happened right after loading a tune...
I had that problem with a vmp tune, the equizzer value didn't match. I'm pretty sure I had a code for something. Just looked in my email and I was getting Code p2101 and p2107 before I even tried to start the car.
I am going to check the pinouts on the PCM.
I just hope I don't need a new PCM.
I've changed tunes a lot and that's always in the back of my mind.
When I crank.it over I get rpm, maf volts, fuel pressure. But spark sits at 10 degrees, doesn't move.
I checked the pinouts in the pcm and when I ground out the cop pins the all get a signal. So there is power at the pcm.
The pcm is just not firing the cops.
Going to give it 2 or 3 hours today again.
So I removed the MAF, TPS, Actuator, Fuel Injector, Cam, Crank, COP, fuel pressure, etc connectors
I installed the crank and cam sensors.
I checked for spark pulse and I got it. WTF!!!
I checked each COP, have pulse now.
Then I added back in the injectors. Still good. Then the MAF, then the TB. Still have spark pulse.
Car still wont start.
I noticed this crazy noise from the TB. The actuator sounds like a forklift.
No codes.
So now I have spark and fuel and it still won't start.
I noticed the TB blades close when trying to start the car.
I still think I need a PCM, but I got spark back today for whatever reason.
*** Anyone ever notice the TB blades closing to start?
I have kind of had it with the car. 15k spent on a new engine to deal with an electrical or PCM issue.
No codes.
