p0133 code wtf
Old Aug 10, 2013 | 08:19 AM
mse5787's Avatar
mse5787
Default p0133 code wtf
Can any give me an idea of what this code means, and what I can do to fix it. I just replaced all 4 02 sensors a few weeks ago, this popped up yesterday evening.
Any help is appreciated
Matt
Old Aug 10, 2013 | 08:26 AM
JCON's Avatar
JCON
What does that mean?
This involves the front oxygen sensor on Bank 1. This code indicates the engine air fuel ratio is not being adjusted by the oxygen sensor signal or the ECM as expected to do so, or not adjusted as often as expected to do so once the engine is warmed or under normal engine use.
Symptoms
You will likely not notice any drivability problems, although there may be symptoms.
Causes
A code P0133 may mean that one or more of the following has happened: The oxygen sensor is faulty The wiring to the sensor is broken / frayed There is an exhaust leak
Possible Solutions
The simplest thing to do is to reset the code and see if it comes back. If the code comes back, the problem is more than likely the front Bank 1 oxygen sensor.
You will likely wind up replacing it but you should also consider these possible solutions:
Check and fix any exhaust leaks
Check for wiring problems (shorted, frayed wires)
Check the frequency and amplitude of the oxygen sensor (advanced)
Check for a deteriorating / contaminated oxygen sensor, replace if necessary
Check for inlet air leaks
Check the MAF sensor for proper operation
Read more at: http://www.obd-codes.com/p0133
Copyright © OBD-Codes.com
Old Aug 10, 2013 | 03:25 PM
mse5787's Avatar
mse5787
thank you jcon, can you answer this is this code talking about the sensor on the driver side before the cat?
Old Aug 10, 2013 | 04:13 PM
moosestang's Avatar
moosestang
Yes it's the upstream sensor (before the cat). Did you replace them with Bosch or motorcraft? Bosch sensors have a history of having slow response time on these cars.
Old Aug 10, 2013 | 04:40 PM
SpartaPerformance's Avatar
SpartaPerformance
I believe bank one is passenger side, same side as cylinder 1. Yes it's the 1st sensor. I also agree with Moose, make sure you have Motorcraft sensors. Aftermarket ones are mostly junk, no good quality control resistance in the sensors could be off etc.... If they are Motorcraft then follow the diag sheet posted above. Why did you replace sensor anyway? Spending money at "guessing" problem is more expensive then having properly diagnosed and replacing parts with OEM components.
Old Aug 10, 2013 | 09:37 PM
mse5787's Avatar
mse5787
yah it is a bosch sensor
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
