clutch problems
Old Aug 21, 2013 | 10:32 PM
66_06_stangman's Avatar
66_06_stangman
Default clutch problems
recently installed new clutch, pressure plate, slave cylinder, and master cylinder. Car shifted perfect for about 100miles then it started getting real hard to go into gear. I tried bleeding it again by pumping the clutch that didnt work then i used a vacuum pump and that didnt work either. I took the transmission back down installed a shim behind the slave cylinder bled the line again with the vacuum with the same result. Has anyone ever had this problem and how can i fix it?
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MasterLanMan
Sep 13, 2015 08:21 PM
Brandonfilipponi@yahoo.com
Sep 12, 2015 11:39 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
