need some input..
Old Oct 21, 2013 | 06:24 PM
86HOGT's Avatar
86HOGT
Originally Posted by SpartaPerformance
What's the offset on the wheels? What size? If you change offset and increase wheel size should also do a Toe adjustment, you should set Toe In 0.01 degree for every step up in width. Ex. if you go from 235 to a 265 front you should set Toe In 0.03 degrees from factory center.
Toe alignment shouldn't be affected by wheel width or offset. The hub is going to put the wheel where it's supposed to no matter the size width or offset.
Old Nov 25, 2013 | 12:05 PM
Whitestang41791's Avatar
Whitestang41791
i am not familiar with spiggot rings.. can anyone enlighten me? what size would i need?
Old Nov 26, 2013 | 10:21 AM
johnny_raincloud's Avatar
johnny_raincloud
Another solution that can be overlooked is that the tires may be cupped...
Doesn't happen often, but it is another possibility!
It happened to me once before. Luckily in my case, great customer service prevailed and they replaced the tires for me after verifying that was the case.
Old Nov 26, 2013 | 12:01 PM
flash_xx's Avatar
flash_xx
You said you got new wheels, but did you reuse the tires? because the tires could be out of round.
Old Nov 26, 2013 | 01:41 PM
Whitestang41791
brand new tires.. any input on the spiggot rings?
Old Nov 26, 2013 | 03:28 PM
flash_xx's Avatar
flash_xx
Some tires come bad from the factory, so don't discard that. As for the hub centric rings, they are just adapter rings you put on the rim to adjust the center bore size to the car's hub. usually made out of plastic or aluminum. This video explains it pretty well:
Old Nov 26, 2013 | 04:20 PM
NTO_GUY's Avatar
NTO_GUY
Former Sponsor
Hub centric rings could be the solution if the center bores are larger. I have seen customer cars with aftermarket wheels have the same issue. Got them the correct hub centric rings and voila, problem fixed. Although, pretty rare for 5 lug cars. 4 lug cars usually have more of an issue.
fearthisinc
Aug 29, 2021 01:59 PM
wydopnthrtl
Mar 8, 2013 06:17 PM
TAMPAGT07
Nov 9, 2012 11:21 AM
Albizo66
May 25, 2012 06:30 PM
fearthisinc
May 24, 2009 11:32 PM
