Best starter mods AFTER supercharging
Old 12-23-2014, 09:27 PM
Mach1newbie
Mach1newbie's Avatar
Originally Posted by 2007CalSpec
OP is in the wrong year forum but I guess the question can apply to all years.
Anyway, I upgraded my rear suspension first and then got the Whipple. Next, I went with a 1pc driveshaft.
Did the driveshaft make much of a difference?
Mach1newbie is offline
Old 12-23-2014, 09:34 PM
2007CalSpec
2007CalSpec's Avatar
I definitely felt a difference. The car was quicker off the line. One of the best mods next to a supercharger.
2007CalSpec is offline
Old 12-23-2014, 09:48 PM
2000AZ5.0GT
2000AZ5.0GT's Avatar
Is your procharger intercooled?
If not, that's the place to start. That will lower your intake temps, so even after driving for 2 hours, the car will perform consistently and put power down.
After that, Headers and a Throttle body will give you a decent bang for the buck *since you're already supercharged*. On a N/A engine, I doubt you would make much power, but with the blower, it will definitely help.
Those things alone will probably get you to where you want, power wise.
But, not trying to be a dick, you may not realize how bad your traction is right now. Most STOCK mustangs benefit a ton from a better suspension, and it is literally the foundation of everything else. But if you don't feel fast enough now, when you get to 420whp and you're spinning even more, you'll feel even slower.
For example, my car probably puts down 350ish (being generous) since it's stock. I can still spin the tires in 2nd - 3rd gear at WOT.
My 2000, when it put down 560hp, would stick on Drag Radials on the street in 1st gear. The benefit was suspension. That same car went 1.67 60' at the strip with street tires. Granted I had a built IRS out of a 2003 Cobra, but I still suggest suspension.
Also, with a new throttle body/headers, you might need a tune to take advantage, and you definitely will should you bolt on an intercooler. Suspension mods will make you feel faster without putting your tune in jeapordy, so that's where I'd start.
2000AZ5.0GT is offline
Old 12-24-2014, 08:01 AM
Soldier GT
Soldier GT's Avatar
I'm prob pushing about 380. I'd like to get around 430-450. It's got pretty good traction now so I'll prob leave that for last.
Probably? Have you ever had your car dyno tuned? If not, that will probably be your best bet. Also with a fairly stock FI 2V you're not going to push 380 to the wheels, more like 350 . If you plan on going over 400 rwhp you might want to think about getting your engine forged.
Soldier GT is offline
Old 12-25-2014, 10:50 AM
Simon1
Simon1's Avatar
Best bang for the buck mods for me, combined with supercharging, was gears and traction mods. Traction mods are a combination of suspension pieces and tires. Tires are my recurring expense that probably sets me back the most.
Another thing to consider is planning a clutch replacement. You probably won't need it at first, or maybe you'll need it immediately. But it will be in the cards for sure.
Having all that power to play with becomes frustrating when all you do is spin tires.
Simon1 is offline
Old 12-25-2014, 12:56 PM
Mach1newbie
Thanks for all the input everybody. It looks like the majority is pointing to getting better suspension mods. I guess that's where I will be starting.
Old 12-25-2014, 12:59 PM
Mach1newbie
Gears are always great! But this is my daily driver and it sees a lot of highway and freeway time. My 72 mach1 has some good gears that made all the difference for that car
Old 12-25-2014, 03:30 PM
Mach1newbie
Yes it is intercooled
Old 12-26-2014, 11:05 AM
Simon1
Simon1's Avatar
You're talking 1-2 mpg difference in highway driving. But to each their own.
That's if you switch to 4.10s.
Simon1 is offline
Old 12-26-2014, 05:30 PM
sactown
sactown's Avatar
go with the gears, it will wake the SC up
sactown is offline
Quick Reply: Best starter mods AFTER supercharging
