Cam position sensor code
Old Oct 23, 2015 | 07:32 PM
mustangfan777's Avatar
mustangfan777
Default Cam position sensor code
Pulled a p0434 which is camshaft position sensor
And so I changed it and erased the codes. Now
The code is back and im getting abysmal gas
Mileage any ideas? Car is an 01 mustang gt
Old Oct 23, 2015 | 10:31 PM
jwog666's Avatar
jwog666
p0434 is an o2 sensor code (P0434 - Heated Catalyst Temperature Below Threshold Bank 2) i will assume you mean p0340
my p0340 was caused by a bad alternator voltage regulator/diode. this caused radio frequency interference that disrupted the cam sensor signal. i rebuilt my alternator and problem was solved. you could try having a parts store run a test on the alternator to see if it is good or not.
67STANGX2
Dec 28, 2015 12:17 PM
gagemcc
Aug 26, 2015 12:37 AM
microgt
Aug 20, 2015 07:12 AM
TheDutchTexan
Mustang Videos
Aug 7, 2015 06:03 PM
