06 Mustang GT Help
Old Mar 24, 2016 | 11:49 AM
bullitt1939's Avatar
bullitt1939
Default 06 Mustang GT Help
Have a 06 Mustang GT show car that won't start. It is giving a code B2103. I have tried another key, brand new battery, fuel pump reset, and swapping fuel pump relay. It turns over, but will not start. I am leaning toward a possible issue with the crank position sensor. Just want to see if any others had this issue and what it turned out to be.
Old Mar 24, 2016 | 07:11 PM
hammeron's Avatar
hammeron
could be the crankshaft position sensor or the fuel rail sensor, both can produce a no start condition.
if it might be flooded, hold the pedal to the floor then turn the engine over for a bit...if flooded, should start within 5 seconds.
Old Mar 25, 2016 | 11:00 AM
Simon1's Avatar
Simon1
http://www.justanswer.com/ford/4ndow...des-b2103.html
Google is your friend...
Best of luck!
Off topic
Hey Hammy!! Haven't seen you around lately. Hope all is good.
Old Mar 26, 2016 | 10:46 AM
Dino Dino Bambino's Avatar
Dino Dino Bambino
B2103 Transceiver internal antenna damaged. Replace transceiver
Old Mar 26, 2016 | 03:44 PM
BrianK's Avatar
BrianK
WTF is an internal transceiver antenna?
Is it beside the turbo encabulator or next to the left nostril inhaler? LOL.
Old Mar 26, 2016 | 06:09 PM
hammeron's Avatar
hammeron
Best of luck!
Off topic
hello my friend, all is well and good to see you are still active! i rarely log on, but do try to keep up with the forum.
Old Mar 26, 2016 | 11:45 PM
Dino Dino Bambino
No. It's a solar-powered antenna that generates a signal for the vortex generators to activate the lubrication system to the muffler bearings.
Seriously, it looks something like this and is on the ignition lock cylinder. It's part of the anti-theft system (PATS):
Old Mar 27, 2016 | 08:09 AM
BrianK's Avatar
BrianK
Thanks Dino. Makes sense - like using a non programmed key.
(I haven't changed my muffler bearing lube oil yet. I'll have to get on that! LOL)
Old Mar 27, 2016 | 09:33 AM
Dino Dino Bambino
While you're at it, replace the synthetic blinker & flasher fluid at the same time. Then you won't have to do it again for another 20k miles.
Mustang Videos
Feb 2, 2016 03:27 PM
blackliststang
Feb 1, 2016 01:00 PM
cb1989
Jan 15, 2016 09:47 AM
Mustanggirl719
Jan 13, 2016 08:48 AM
