Low coolant but no warning
Old 05-08-2017, 02:19 PM
flash_xx
flash_xx's Avatar
Well, found the leak. It's the water pump. Apparently it was leaking slowly at first but today found a puddle under car. Ordered the Edelbrock Victor water pump. Figured I might as well upgrade.
flash_xx is offline
Old 05-11-2017, 10:26 PM
flash_xx
flash_xx's Avatar
I usually don't like to add anything to my cooling system, except coolant and distilled water, but since my new pump hasn't arrived and I have drag racing on Saturday and a track day on Sunday I decided to give these a shot. Amazingly enough they worked?! car hasn't spilled a drop since I added them.
Bar's Leaks HDC Radiator Stop Leak Tablet - 60 grams
Amazon Amazon
I'll have to drain the system anyway to replace the pump so I'm not worried about residue or long term damage from using these, but at least I won't miss all the fun this weekend. I might keep a set in case of emergency.
flash_xx is offline
Old 05-15-2017, 12:32 PM
Simon1
Simon1's Avatar
You go with the electric pump?
As long as there is coolant on there you'll be fine. I would not put anything on there except antifreeze and distilled water.
Simon1 is offline
Old 05-18-2017, 10:40 AM
flash_xx
flash_xx's Avatar
No, went with the Edelbrock Victor water pump
flash_xx is offline
