Clicking clutch noise
Hello all,
I recently swapped my 4.0 drivetrain to 4.6 GT drivetrain, and am having a funky noise issue thats driving me crazy.. I think its clutch/throwout bearing/main shaft related, I would really appreciate some help here.
The noise resembles more of a clicking/light knocking that goes away when clutch pedal is pushed down.. The noise gets faster with RPM. If I can, I will post a small video. Thanks for the help
All new components, except the tranny. Spec 2+ clutch assy. "Stock" flywheel (rockauto), AM throwout bearing.
Tranny has no 5th gear, so I will need to pull trans anyways.. But I would like to be able to put it all back together with confidence.
Can anyone provide any input on this? I noticed through the transmission peep hole, with the clutch pushed in the throwout bearing/clutch disk appeared smooth, and all nosies went away.
Im thinking its the fingers on the clutch disk, the throwout bearing, or the input shaft.. Im really not sure
I have the same issue with my 04, 5 speed , I bought A kit from Rock auto,A standard clutch kit. My mechanic told me that it needs to break in,The more I drive it the parts will make their grooves and it will go away. ?? so far 500 miles and still has the noise
In my video, you can see my TO bearing "jumping" around.. Which I believe is causing the noise. But I have no idea why its doing that.
