PA Performance alternators 130 amp
Old 06-13-2018, 11:55 PM
stealth_GT
stealth_GT's Avatar
Default PA Performance alternators 130 amp
https://www.americanmuscle.com/sr-13...tor-0508gt.htm
Are these things pretty reliable? Some mixed reviews but mostly good with some people saying that they'll melt within a few months lol
stealth_GT is offline
Old 06-14-2018, 12:33 AM
stealth_GT
stealth_GT's Avatar
Well what the hell... battery voltage is at 15.8/16.0 so it's seems ok. No flickering or weird idle issues. I did get the P0340 cam shaft sensor code but it was right after installing a 91 octane tune (running 90 gas) and it was on acceleration and letting off the throttle when I got that code so....
I'll check again in a couple days or sooner. Leaving in July for three weeks so it'll just sit around anyways..
Old 06-14-2018, 12:38 AM
outceltj
outceltj's Avatar
I put one on my car sometime ago and I haven't had any issues. I recently installed that high torque mini starter. Starts the car much easier. Less noise and its unique.
outceltj is offline
Old 06-14-2018, 01:30 AM
stealth_GT
stealth_GT's Avatar
That's great to hear. High torque mini starter? I gotta look into one too!
Anything to keep her alive and running. I'll have to change out the spark plugs this winter too, which will be fun. I'll keep the Lisle tool handy lol
Old 06-14-2018, 01:43 AM
Dino Dino Bambino
Dino Dino Bambino's Avatar
That voltage is too high and sooner or later it'll damage the battery. Looks like your alternator has a faulty voltage regulator.
Dino Dino Bambino is offline
Old 06-14-2018, 02:41 AM
stealth_GT
stealth_GT's Avatar
Gotcha.. so new PA alternator it is...
Old 06-14-2018, 04:41 AM
08'MustangDude
Banned
08'MustangDude's Avatar
Charge voltage should be no more than 14.4, no less than 13.7, with a test
meter at the battery terminals.
At 15.8+, not only will it eventually ruin the battery, your lights will
burn out quicker, but, will be brighter.
08'MustangDude is offline
Old 06-14-2018, 03:44 PM
bl817
bl817's Avatar
if it were me, I would go with a Ford Motorcraft 2010 alt in either manual trans or auto, whichever applies. good luck
bl817 is offline
Old 06-14-2018, 04:34 PM
stealth_GT
stealth_GT's Avatar
Thank you for the info. What's up with the 2010 alternator? much needed upgrade?
Just confirmed mine has a bad diode via hand held scanner.
I already ordered an American Muscle PA high performance 200amp alternator.
Crosses fingers.
Old 06-15-2018, 02:19 AM
Dino Dino Bambino
PA = Made in China so good luck.
Quick Reply: PA Performance alternators 130 amp
