well.....Got an SVO
well.....Got an SVO
I decided not to do the 2.3t swap car that i had planned but instead to just buy an 84 svo with 37,900 original miles on it for 3,000$
[IMG]local://upfiles/31982/8588187CABCE481BA6320C694A820E80.jpg[/IMG]
[IMG]local://upfiles/31982/73698C4955BB40B29E54133E1F07F5B7.jpg[/IMG]
[IMG]local://upfiles/31982/A2B8ADD2084C4891B6DE16438025C0DE.jpg[/IMG]
RE: well.....
here is all the parts that i have from the swap that will be going on the svo in the next few weeks (minus the head that will be next summer)
Head: Ported, big valves, e2277 turbo cam
Intake: Gutted 120 degree rotated upper, ported knifeedged lower, 65 mm throttle body
Manifold: 3rd gen, coated bob's log
Exhaust: Stinger complete 3 inch single to 3 inch warlock muffler dumped.
Intercooler: Large fmic with 2.5 inch tubing and a turbosmart bypass valve.
Fuel System: Walbro 255lph pump with 42 lbrs injectors
EEC: LA3 and innovative lm-1 wideband kit.
Rearend: 8.8 with 3.73's
Suspension:upr upper and lower control arms new urethane bushings
Brakes: Stock for now but already have 04 cobras for the front
RE: well.....
That is awesome! $3000 for a car with that kind of mileage is a really good deal if you ask me. You are gonna have one quick ride with all of the go-fast goodies you've got there. Any plans for a bigger turbo? With everything else you are doing to increase the airflow theT3 is going to hold you back in the power department.
It looks like you have done plenty of homework on your setup, but have you considered how you are going to tune with the 42lbrs injectors? I don't think the LA3 is going to like them without the J3 or other management system.
RE: well.....
ORIGINAL: hellion_79
OMG that is a sexy SVO []
I hope they are still around when i get a job and have the money for one It seems like they get rarer each day cause everyone is molesting them
RE: well.....
ORIGINAL: TRBOPWR
RE: well.....
About the same set-up as I'm thinking of doing. I've got a Holset HE-351? (I think that's the numbers) and Stinger header to avoid the downpipe thing. I am going to try not to ugrade the injectors though, I'm thinking that the meth will make up for lack of fuel. Good luck with your project!
RE: well.....
ORIGINAL: pfs4life
wtf hellion??
RE: well.....
that holset uses up feul like crazy, the stock injectors (35 lbs) are good up until about 300 hp. The Holset will push you well past that so you may want to look into new injectors. The meth will help but not fix a lean issue that you will most undoubtedly have.
RE: well.....
ORIGINAL: TRBOPWR
