HELP!!!!
My name is B
ill and need help putting a head gasket on a 92 2.3 liter 4 cyl.
I am down to taking the head off and am scared I will screw up if I take the timing belt off wrong or the valve train. Can anyone help?????
It is a 1992 mustang with the2.3 liter engine and has 150000 miles on it but I am going to drive it because I cannot get anything for it. Thank you,
Bill
Bill
You cant really take the timing belt off wrong, just make sure its timed correctly when you put it back together. Id suggest getting a new belt well your at it too to save yourself a future problem.
I would replace the belt and the tensioner while you're in there.
chances are you'll be using an aftermarket timing belt when you put it back together. once you put the new belt on and get tension on it, rotate the engine twice (don't force it if you feel a sudden stop or excessive resistance) and make sure the timing marks line back up afterwards. You may end up having to adjust a tooth if it doesn't.
also don't skip resurfacing the heads. You'll end up doing the job again in 10k miles give or take.
2.3 is non interference engine so belt timing wrong will not hurt anything. "A good manual is good idea." Check the belt timing here. I know turbo site but timing is exactly the same. Be careful with the crankshaft sensor and not damage it. [Will cause no start problem] Maurice
http://www.stinger-performance.com/tech.html
