4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
do i need...
Old Aug 12, 2006 | 12:37 AM
slowpokelx's Avatar
slowpokelx
Default do i need...
do i need a new computer if im swapping a auto to a 5spd...?
86_GT_Mustang's Avatar
86_GT_Mustang
Default RE: do i need...
nope
Old Aug 12, 2006 | 12:39 AM
slowpokelx's Avatar
slowpokelx
oh thank god. :P ive had a hell of a time getting the parts i needed.
thanks man!
Old Aug 12, 2006 | 01:03 AM
alexr's Avatar
alexr
did you get EVERYTHING? theres a lot of ****.
Old Aug 12, 2006 | 01:10 AM
86_GT_Mustang
ORIGINAL: ARdoller
Oh yea i forgot to mention that ^^
Old Aug 12, 2006 | 01:14 AM
slowpokelx's Avatar
slowpokelx
Yeah i got everything! that is on this list...
Borg Warner T5 Transmission
Bell Housing (Engine Specific, 5.0 or 2.3)
Pivot Ball
Starter Plate
Clutch Fork
Clutch Cable (And Dogbone Cable)
Clutch Cable Clip (Holds Cable In Housing)
Clutch Quadrant (Part Of Pedal Assembly)
Clutch Disc
Pressure Plate
Flywheel
Throwout Bearing
Pilot Bearing
Pedal Assembly (Engine Specific, 5.0 or 2.3)
Shifter
Shifter Bezel
Shifter ****
Shifter Weather Seal
Shifter Boot
Drive Shaft (2.3 Only)
Back Up Light Harness (Plugs into Tranny)
Exhaust Hanger Bracket
Manual Transmission Crossmember
Bolts and Mounting Hardware (Pressure Plate, Bell Housing)
the only thing i do have to get tho, is the crossmemeber bushings and bolts. and im set. :]
Old Aug 12, 2006 | 01:28 AM
alexr's Avatar
alexr
sweeeet. i was gonna start that, but all the junk yards ive been to, the only 5spd foxes they had were already stripped of all the drivetrain components.
Old Aug 12, 2006 | 01:31 AM
slowpokelx's Avatar
slowpokelx
I'll keep a look out for you if you want?
Where i got mine, the guy says he gets them in a lot. The only problem i had was the bolts for the crossmemeber we rusted out along with the bushings.
Old Aug 13, 2006 | 12:50 AM
TBird232ci's Avatar
TBird232ci
In all honesty, it would be best to get a 5-speed computer. The 5-speed cars have revised IAC tables, so that when you put the clutch in, it doesnt let the RPMs drop hard and stall the engine.
Do you need it? Not really. Would it be best if you got it? Yes.
mtflyboy25
Feb 28, 2013 03:21 PM
Ecto96
Aug 2, 2012 03:39 AM
badlx87
Jun 3, 2012 12:02 PM
specizripn
SVT Forums
Dec 21, 2011 05:32 AM
1992 5.0 lx
Jun 20, 2009 07:40 PM
