Has anyone swapped a 2.3L OHC for a 2.3L Duratec in their 'stang?
ORIGINAL: Rustang Racer91
Another thought about "custom powerplants" a 3.8L super coupe motor in a fox body? that would be fun. Or a turbo'd 3.8L in a fox...maybe a t-4? just food for thought.
Let's see if we can revive this post.
Can the 2.3 Duratec be installed in a fox body mustang?? (2001-2008 ford ranger engines)
A T-5 bellhousing is needed and be found here : www.quad4rods.com
What about engine management??options
1. Can the Ranger computer and harness be integrated into the Mustang??
2. Stand alone systems (megasquirt etc.....)
Do they use the same motor mounts or need different one (aftermarket or fabricated/custom)
It would be interesting to see if this can be done.
I havea 93' 2.3 coupe and would like to upgrade it's powertrain while keeping it economical.
- Joe
- Joe
First things first welcome. Well check here they seem to have a bellhousing.
http://quad4rod.accountsupport.com/i...t&Itemid=1
As also read this page
http://quad4rod.accountsupport.com/i...&Itemid=29
Says it is in the Ranger that is rwd. The standard shift truck trans probably would not work. But maybe automatic. Should be a 4 or maybe 5 speed use the truck wiring in the mustang. A lot of work. This is what I am doing to the MGB 2.3 turbo. Using the turbocoupe wiring and autometer gauge.
Megasquit would probably easier but cost. Would need to check with them before buying.
just throw a 03-04 cobra drivetrain in it motor trans and rear. it all bolts right in... then get your wiring harness and pcm and ecm and youll have one bad *** little fox
The Cobra idea has been done. I think he is wanting something differant. A Cobra drivetrain probably would not be reasonably priced. Let us face most people in the section of forum can't afford a expensive drivetrain and put gas in it. I read in the hotrod link a 4 cylinder duratec can go 300 hp. Maybe expensive but who say it has to be done in one shot. Now that gets interesting. Affordable on gas and power. Best of both worlds.
Amazing what will find on net.
http://www.mcsorley.net/locost/powertrain/default.htm
http://www.rsoc.co.uk/showthread.php?t=91651
While he mentions a few problems. One of them is clutch cable. This is solved with a t-5 hydralic clutch bellhousing I THINK some of the turbocoupe's has this. A crank sensor also a problem. Maybe a front mounted one. Like maybe one made for the 2.3 converted to edis.
ORIGINAL: 92lxsleeper
if u wanna be different, put some vtec in there.[8D]
JUST KIDDING!
JUST KIDDING!
sounds interesting
more info. Have to read on down. Using a ranger trans or miata trans. Interesting.
http://www.turboford.net/ubb/ultimat...c;f=3;t=025190
