4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
Has anyone swapped a 2.3L OHC for a 2.3L Duratec in their 'stang?
Old Dec 5, 2007 | 04:58 PM
CODENUT's Avatar
CODENUT
Default Has anyone swapped a 2.3L OHC for a 2.3L Duratec in their 'stang?
I've been thinking about it. Swap the old for the new. I mean, Cosworth is getting 250 horse n 265 torque outta the Duratec...and that's NA. Might be something worth trying.
Old Dec 5, 2007 | 06:15 PM
bacon57's Avatar
bacon57
Default RE: Has anyone swapped a 2.3L OHC for a 2.3L Duratec in their 'stang?
If I'm not mistaken, they are 2 completly different engines. The new ones would be cool but I doubt the old transmissons would bolt up, meaning you would have to either redo your front suspension and install a transaxle or fabricate all kinds of stuff to get it to bolt up to a rwd tranny, and even after all that you would have to find a computer to run it.
You'd be better of just trying to get a 5.4 4 valve out of a Navigator to put in there.
Old Dec 5, 2007 | 06:23 PM
pfs4life's Avatar
pfs4life
now that wuld be interesting
Old Dec 5, 2007 | 08:01 PM
CODENUT's Avatar
CODENUT
haha any 5.4...intech or 3v...would be nasty. i was just seeing if anybody tried the duratec swap. yea im sure its alotta work....prolly have to custom make a bellhousing, even prolly bore the end of the crank to accomodate the bigger input shaft. also you'd have to either get a different clutch or input shaft fabbed up to spline right. PCM could just be used outta a fusion/milan. lol then again im a ford tech i could get the wiring diagrams easy to connect the network of modules together. i dunno...i think it b pretty cool seeing that tho.
Old Dec 5, 2007 | 08:09 PM
bacon57's Avatar
bacon57
It would definatly be different, I am not a big 4 cylinder fan, I only have one because I am 17 and poor. For the work a Navigator motor would be the coolest thing on the road and probably run 12's.
Old Dec 5, 2007 | 08:28 PM
sleeper_inc's Avatar
sleeper_inc
The Duratec is a East Westengine design, when the 2.3 Lima is a North South design. LOTS of CUSTOM work is going to need to be done in order to get the duratec to work
Old Dec 5, 2007 | 08:39 PM
mg man 75's Avatar
mg man 75
Like anything can be done. Convert to North south. Custom bellhousing. Probably megasquit for control of engine. But why when a 2.3t will bolt in over a hard weekend and be done except tuning and fun. Now here is something I am thinking about. Looking for convertiable mustang to do it in. Found the motor. Going to use aerostar automatic. But a person could per this link use a t-5. http://members.tcq.net/rlstrand/ I know in a mg but it is a ford motor and a t-5. Question is how will it fit a mustang as far as where shifter will be and overcam head will be. May have to shift all forward and that would mess up a t-5 swap but no problem on automatic.
Old Dec 5, 2007 | 11:13 PM
FoxGT's Avatar
FoxGT
Navigator swap has been done quite a few times, dare to be different! or navigator it... i dont care lol
Old Dec 6, 2007 | 09:21 PM
Stang2.3's Avatar
Stang2.3
Just Be Original Get a 302, and Stroke it, Spray it, Turbo or Charge it..... Then the Moeny Saved from the Custom swaps could be put into bettin against those Civic's lol
Old Dec 8, 2007 | 02:08 PM
Rustang Racer91's Avatar
Rustang Racer91
Another thought about "custom powerplants" a 3.8L super coupe motor in a fox body? that would be fun. Or a turbo'd 3.8L in a fox...maybe a t-4? just food for thought.
