4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
Factory Boost controller question
Old Jun 15, 2008 | 07:06 PM
icelandismine's Avatar
icelandismine
Default Factory Boost controller question
...Where is it? Sorry for the stupid question, but, I have very little idea...1986 Merkur. Is it the boost control selenoid? I hope not, because I've pretty much gutted the wiring for it so far and I don't want to rebuild the loom.
Old Jun 15, 2008 | 09:05 PM
mg man 75's Avatar
mg man 75
Default RE: Factory Boost controller question
Put in adjustable control or diy. Do search worded. DIY boost control. Darn forum won't let me do a link.
Old Jun 16, 2008 | 12:41 AM
FoxGT's Avatar
FoxGT
Like he said you can build one. I've built about 10 of them for customer/friends. I just finished one actually for my friends '85.5 svo a few days ago.
They cost about $15 to build & you need a drill/tap. You may need a bit the size of the ball to grind out some material, most times the ball doesn't like to fit well.
I build all of mine with a drill press & the same tap. I use two different bits. They're pretty cheap though.
The only real trouble you may have when building one is springs. Some springs have different rates so you can't go by just size alone. Thats easy to fix though, get a spring make a run in 2nd gear 1/4 - 1/2 throttle & to test it. If it overboosts, cut the spring a little shorter & keep repeating until you get it the right size.
Better to diy though, No point in wasting $50 for a boost controller. I did that like 4 years ago for my first turbo project, took it apart & couldn't help but notice that every single part to it they had at the local hardware store other than the ****.
Granatelli Sales
Jan 20, 2020 12:34 AM
Galactic
Apr 29, 2019 02:56 PM
04stangman
Sep 17, 2015 01:45 PM
cbird1177711
Sep 2, 2015 04:12 PM
