i took some pics of my intake
well it actually just happened again when i tried to drive it again but i just felt like it died then it backfired. my friend who works on cars thought it could be the fuel pump going because it would stay on and when he stomped on the gas it would go no where. my intake is messed up mind you and my exhaust has a hole in the muffler. i got a couple buddies that are going to help me with the swap in the next couple days hopefully but i dont think im going to have the turbo engine dropped in within driving time so i might need to see what is wrong with this engine first. im going to check the spark plugs tomorrow because my friend also suggested a tune-up/timing problem.
Check the codes, the computer might have something even though the check engine light isn't on. Make sure your EGR valve is working properly, they like to clog up and hinder acceleration, leaving it in carb cleaner over night will clean it very well. Then check the o2 censor. I don't think having a hole in your exhaust would be a factor. Your intake maybe, test the coil pack you plugged back in also.
When he stomped on the gas did the car die?
this all started to happen after i plugged back in the sensor thingy shown in one of my pics that you told me to plug back in. after my tach started to work i was shifting at much higher RPMs than before because i actually saw my RPMs. then it died after that. could it possibly be because i plugged that in? how would i check the coil packs?
well i took it to them and they checked it for continuity, and everything passed. the primary was a little high he said, he said it was supposed to be in the .3-.7 range and it was about .9 but besides that they passed for cont. i took a spark plug to Advance Auto Parts and he said it was fouled out, he said it could be a possibility of it just needing new plugs and wires. a buddy of mine suggested the fuel pump to be going out but the guy at auto zone said it was most likely an ignition/electrical problem like plugs.
well should i just replace the spark plugs thinking its the problem? i drove the car today and it didnt die. it stalled once but that may have been me shifting from reverse to 1st and letting the clutch go too soon. when i try and stomp on it it the car rattles and doesnt want to go any faster unless you slowly accelerate.
