What is required to swap a c4 transmission into a 1993 2.3 mustang? should i use stingers plate to convert the bellhousing? but then what about the flexplate and the torque converter??? or is there better ways?
Are you wanting to run a pinto or a V8 C4? the pinto one is a direct swap, but if you do the V8 you'll either need a custom converter or a custom flex plate
