help on body work?
help on body work?
well i finally got my 1st car and its a mustang 2.3 notchback 5spd and seems as perfect can be execpt the kinda overly senstive gas and latish grabing clutch(which got replaced). and everything is perfect except for a very very annoying dent right behind the front fender on the left side. i think i could hit it out with a hammer from the other side but i dont kno how to take it off? any help would greatly be apretiated.
try to keep away from hitting the back with a hammer if possible. If you can, i'm sure your school may have some. Get a dolly near the same shape of where you're going to need hit out, Hold the dolly firmly on the back side of the fender & hit the outside with a hammer (somewhat lightly). If you're worried about paint, you can put a bit of tape over the end of the hammer. The hammer isn't what's doing the work, the dolly is.
When done with that if you want to try to get it looking perfect again, bondo over the area (make sure to go a bit past the dent to ensure you got the whole dent. After it dries, grab a paint stick, some 100 grit sand paper. Wrap the sand paper around the paint stick, hold the stick horizontally & sand diagonally. then you primer/sand/primer/sand. Don't go over 400 grit with the sanding on primer.
Make sure you remove the paint to bare metal if you bondo it.
Pics won't really change what has to be done either way. If it's dented in very far, it's best to use a dolly/hammer to get it out before bondoing. Bondo is horrible when applied thick. The priming & sanding will be the same for any ding.
Some spots that you can't get to the back of you can drill a hole for a screw, or weld a piece of metal to the tip of the dent & use a slide hammer to pull it out. Fenders are generally easy to get behind though.
get a heat gun on low and heat up the bumper cover very slightly and pull it back into place hold it there until it cools down might do the trick,
if the school has a body shop let them do the dent easyer on you,
