4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
Code 114...
Old Jan 23, 2009 | 01:21 PM
dreamer1uk's Avatar
dreamer1uk
Question Code 114...
Hey all,
Has anyone had any experience with this 114 code? My 93 Stang has been idleing funny as of late. I was assuming the bad idle was related to my IACV (was planning on cleaning that when i do a tune up soon) as well as her needing a tune up anyhow. But after changing my oil today and using my OBD1 scanner for the fun of it, this code popped up.
I know it has something to do with the Air Charge Circuit been out of self test range so, any help would be great.
Ive been searching the forums and no luck thus far.
Thanks for any insight
Old Jan 23, 2009 | 02:41 PM
sleeper_inc's Avatar
sleeper_inc
Thats your air intake temp sensor.
Best bet is to replace it
Old Jan 23, 2009 | 04:09 PM
dreamer1uk's Avatar
dreamer1uk
Hi,
Yeah, i bought the new IAT from Autozone. So ill install it tomorrow and see how it goes.
Old Jan 25, 2009 | 09:25 PM
dreamer1uk's Avatar
dreamer1uk
Hey,
I installed the new IAT sensor the other day and it seemed to calm my idle while the engine was cold.
However, after i arrived home from work, i decided to change my PCV valve as i know they can cause some irratic idleing. After changing that, my idle issue was gone and shes idleing perfectly now.
So, if anyone else ever has a wierd idle, id look at the PCV valve first before assuming its the IACV
Hope this helps someone.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
