4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
a little help with a 2.3t
Old Apr 25, 2012 | 08:05 PM
red88stang's Avatar
red88stang
Default a little help with a 2.3t
heys guys,
im looking into buying a 2.3t from an 88 i believe.. the one with an intercooler ontop.
im gonna swap this into a sandrail. It doesnt come with a computer or harness, what harness and computer would I need?
Old Apr 26, 2012 | 10:22 AM
mg man 75's Avatar
mg man 75
Computer from a 87-88 turbocoupe. You need a large Vam. Now for wiring, there is a company that makes a standalone one.
http://www.ronfrancis.com/prodinfo.asp?number=MG%2D65
Or a 88-about 90 2.3 Mustang and then repin add wiring for the Vam. Naturally probably cheaper but more of a challenge. It is a standalone harness. Unsure how you skill as far as wiring. [Reading a wiring diagram etc] How to do that part of it. Also site has bunch of info of what may need.
http://www.stinger-performance.com/turboswap2.html
Wiring diagram if going this way.
This harness does terminate to a plug. The other 2 connections are ground and battery. But still you need to add keyed hot, grounds, fuel pump, tach and few others.
Maybe a 4plug Ranger. Just unsure if it is standalone or has bunch of extra wiring in it.
A Merkur 2.3 is also a standalone harness. These car getting hard to find.
Hope that helps Maurice
Old Apr 26, 2012 | 10:32 PM
red88stang's Avatar
red88stang
that stand alone harness is a bit too much...
im not bad at wiring stuff up..i think i'll go that route if i go for it.
i was reading that if you use a harness from a non turbo u have to wire in for the vam.. i think this engine was converted to maf, would that make it easier to hook up or more messing with the harness?
Old Apr 26, 2012 | 11:33 PM
red88stang's Avatar
red88stang
i went on o'reilly parts and the have the computers from the regular 2.3 and the turbo 2.3 from the thunderbird for around 100 bucks.. all i would have to find is a harness.. need to do a little more research on which would be easier to do
pfs4life
4 Cylinder General Discussion
25
Apr 12, 2008 04:54 PM
Street_Racer
Mar 4, 2008 10:05 PM
65coupe88hatch
Mar 8, 2007 12:14 PM
SmallBlockFloyd
Nov 7, 2006 03:25 PM
crono61
Oct 8, 2006 04:13 PM
