4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
1979 2.3l No Start
Old 09-07-2016, 02:58 PM
Carography
Carography's Avatar
Default 1979 2.3l No Start
I will try to be as succinct as possible.
I rebuilt the head out of a '80 Courier and installed in our 1979 Mustang. This is the first time i had ever done anything this complicated. Given that, I was thrilled to see the engine crank and turn over when we turn the key.
But no start.
The car ran fine when the head seized up and broke the timing belt.
We have put fresh gas in the tank and have confirmed that fuel is moving to the carb.
I have double check the firing order.
I cleaned the carb as best I could when I had the top end off the engine.
New spark plugs.
Here is a video. it shows a back fire out the carb.
https://photos.google.com/u/1/photo/...DdTb-mOMNzf4iR
That is all the information I can think of now. Any and all input is appreciated. Please let me know if I have left any helpful information out.
Carography is offline
Old 09-08-2016, 08:23 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Welcome to the forum.
A backfire thru the carb usually is a timing issue. Verify TDC with timing marks on balancer. And make sure distributor is installed correctly, not one tooth off.
And what's with the word "succinct" ??? This forum is for simple people lol.
Good luck, and post back with any updates.
88 orangepeel notch is offline
XForce USA
XForce-USA
08-08-2016 01:28 AM
ranger90
07-21-2016 03:35 PM
XForce USA
XForce-USA
07-19-2016 12:02 AM
exist
07-18-2016 10:34 PM
mvancopp
SVT Forums
07-11-2016 04:31 PM
Quick Reply: 1979 2.3l No Start
