BELT SIZE
RE: BELT SIZE
depends on the kit your using cause if you just remove the smog pump, ps pump and ac its not possible to run a belt around the crank, wp and alt without a tensioner kit of some sort. ive seen the alt on both sides of the engine when using just the 3 pulleys and a tensioner. there is also a couple different tensioner relocation kits. best bet is to get a medium gauge wire such as 10g and run it along the route the belt will be run and then messure the wire.
RE: BELT SIZE
ORIGINAL: luckythirteen13
RE: BELT SIZE
http://www.marchperformance.com/pg30.html about half way down the page they have a kit for what you want
autoedit
09-27-2015 06:37 PM
09-25-2015 06:58 PM
