88 ford mustang smokin
RE: 88 ford mustang smokin
Ok, this might sound funny, but do you smell an almost "sweet" smell? This is kinda like antifreeze.
Got a question for ya. Does it happen only when the engine is hot or when you first start it up?
do a compression check...the guage cost about 25 bucks. disconnect your fuel pump fuse or relay (so the motor won't start when you crank it). pull one spark plug at a time and screw in the guage. it helps to have a friend here crank it over so you can watch for "ticks" on the gauge. count 5 "ticks"or you can just crank it yourself and go look at the guage. all eight cyliders should be around 150psi. that will tell you if you popped a head gasket or burned a ring/pistons. basically it'll clear up the worst case senarios. otherwise it could be an lower intake gasket (coolant) or valve guide seals in the heads (oil)
Diode Dynamics
28
05-26-2022 12:02 PM
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
NTO_GUY
12-24-2015 11:23 AM
08-10-2015 01:44 PM
