dash lights went out
Hi guys,
Well Since I've had this car the dimmer switch has always been a kinda jacked up. in order to get the dash lights and the headlights on at the same time I had to pull the switch all the way out, and then slowly push it back in until the dash lights went on. If i pushed too far, the headlights would go out and the dash lights would stay on. But yesterday the dash lights didn't work at all. I had to drive home with just headlights. What do you think the problem is? if its the switch, where can I get another one?
thanks.
thanks.
RE: dash lights went out
Could be a fuse. The switch could be the problem also but I would start with checking the fuses. Also when you push it partially in the switch the dash lights are supposed to stay on and the headlights stay off. Thats normal.
09-25-2015 09:06 AM
