Carb conversion
Old Mar 1, 2006 | 11:05 PM
matts88's Avatar
matts88
Default Carb conversion
i want to convery my perfectly good EFI 5.o into a carbed power machine. i know that EFI is a more accurate fueling system but i like the easy tunning of carbs. how hard do you all think this would be and what all will i need other then a carb, and intake, and a distributor. if theres anything im missing please let me know.
Old Mar 1, 2006 | 11:33 PM
hotstang97gt's Avatar
hotstang97gt
Default RE: Carb conversion
i think all you need is carb and intake. the dissy should be the same. if you convert it to carb then you will ned to block off one of the fuel lines
Old Mar 1, 2006 | 11:45 PM
Quik's Avatar
Quik
you need different dist, different fuel pump, intake, carb, i forget what else
but why honestly do you want to go slower?
Old Mar 2, 2006 | 12:58 AM
tinman's Avatar
tinman
Need to run fuel pump externally unless you have a pre '86 block.
Need differant pick-up tube in tank.......
Old Mar 2, 2006 | 01:25 AM
5.7litereater's Avatar
5.7litereater
you can use the stock in tank fuel pump if you want. Just get a fuel pressure regulator and bump it down to say, 7 psi.
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
