speedometer
Old Mar 3, 2006 | 04:42 AM
95bayouracer's Avatar
95bayouracer
Default speedometer
The guy that did my gears does really great work but i left his shop not knowing that my speedometer would be off. how can i fix this
Old Mar 3, 2006 | 05:13 AM
ikeybmg's Avatar
ikeybmg
Default RE: speedometer
you have to order the replacment speedo gear that goes with the gears you have. theres a drive gear and a driven gear, they are in the tranny. its like 10 to 20$ is all. theyre relativly easy to install too. you can order them from any place that deals with mustang performance. try summitracing.com
Old Mar 3, 2006 | 12:46 PM
95bayouracer
thanks. i will do that pronto. im just a little paranoid not knowing how fast im going.
Old Mar 3, 2006 | 01:32 PM
sc94gt's Avatar
sc94gt
I didn't see them on the Summitracing site when I looked for mine or even Jegs.
I know Steeda has them on there site.
Old Mar 3, 2006 | 01:41 PM
mrmtri3's Avatar
mrmtri3
5.0 resto has them and the guy that did my gears got the speedo gear from the Ford dealer
Old Mar 3, 2006 | 05:36 PM
95bayouracer
thanks guys
Old Mar 3, 2006 | 05:45 PM
gspfunk's Avatar
gspfunk
ORIGINAL: mrmtri3
X2!!!
Old Mar 3, 2006 | 08:39 PM
nitrous_bob's Avatar
nitrous_bob
you probably won't be able to correct 100%
'95 T5's used a 8tooth drive gear, and even w/ a 23 tooth driven gear (which will correct for 3.55's but isn't a ford gear, and will wear out from having so many teeth) you can't correct 3.73's or higher.
w/ 3.73's you need a 7tooth/21 tooth combo or a 6 tooth / 18t combo
4.10's you need a 6t / 20t combo (or a 21 if you must...but they suck...wrong pitch as well)
the tailshaft has to come off, to replace the drive gear...it's clipped on the output shaft.
articman
Jun 21, 2018 11:45 PM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
Nurdyguy
Aug 21, 2015 10:23 PM
danclint
Nov 28, 2004 10:32 PM
Leadfoot
Sep 10, 2004 03:05 PM
