Look what I got!
#61
RE: Look what I got!
ORIGINAL: Black Snake
Getting it installed Next thursday, and it costed me 1700 for the Charger and another 400 for the pulley, powerpipe and By-Pass tube. Ill be pushing the same amount of boost as the S-Trim, for a much cheaper price.
Glad to see another 5.0 taking the climb to the boost level playing field. I will recommend that you install the inline fuel pump. The added protection will ensure the proper amount of fuel is always on tap. They say with a proper tune you can get rid of the FMU, however just to be safe, I plan on keeping mine intact.
Good Luck on your build and I agree with the others that you got one hell of a deal with the all the work for $400. Take pictures of the install if you can and let's see those dyno numbers too.
BMN
#62
Im going to be pushing the Same boost and keeping the stock pulley, so I dont void my Waranty. The Stock S-Trim is rated at 8-9lbs of boost and mine is rated at 6-7. With these new parts ill be pushing close to 9-10lbs.
If I were to use these parts on a S-Trim I would be pushing closer to 12-15 lbs. But I dont want to push the motor.
I went with a bigger crank so I can get more boost at Lower Rpm, Im never going to take this bad boy past 5000 Rpm.
So I want to be able to make about 6-8 lbs at boost at around 4500 Rpm. If that makes sense at all.
