No Cruise Control !!!
Old Mar 8, 2006 | 02:51 AM
Madskillz306's Avatar
Madskillz306
Default No Cruise Control !!!
Hey All, Just wondering if anyone ever had issues with Cruise Control no longer working after upgrading Engine. I have built up 306 and never noticed cruise didn't work until i tryed it tonight. always worked before and besides that everything working ok.
not a big deal but nice to have as the car is fully loaded and would rather it working if possible.
any ideas anyone.
car is 1991 Gt.
stock 302 was swapped with 306 built up from oil pan to upper intake.
Old Mar 8, 2006 | 09:27 PM
1990mustanglx's Avatar
1990mustanglx
Default RE: No Cruise Control !!!
yea my horn cig lighter heat cruise control and light speedo and odometer dont work and i dont know why any of them dont work
Old Mar 8, 2006 | 09:29 PM
lookinforastang's Avatar
lookinforastang
I ♥ Acer
usually a blown fuse.
sorry im only familour with GM's cruise systems
Old Mar 8, 2006 | 09:48 PM
wildcobrar's Avatar
wildcobrar
Make sure you have all vacumn lines hooked up because the Criuse works off vacumn too.
Old Mar 8, 2006 | 09:50 PM
95stang5.0's Avatar
95stang5.0
yea mine was a fuse it had horn, curise control and my rewiered foglights on it it was a 20.
Old Oct 28, 2010 | 12:08 PM
beamotorman205's Avatar
beamotorman205
yes have same problem checked fuse , fuse is good,goin crazy tryin to figure it out any help would would be very thank full
Old Oct 28, 2010 | 12:14 PM
beamotorman205
1989 lx 2.3, no cruise, checked fuses ,vaccum hose, all plug s are tight, need help thanks
Old Oct 28, 2010 | 09:24 PM
Bubba 95SN's Avatar
Bubba 95SN
Something as simple as bad brake light bulb. Check vacum dump valve at brake pedal. Pull on cable may be broken where goes into servo. After that servo and amplifier tests.
Old Oct 28, 2010 | 09:25 PM
Bubba 95SN's Avatar
Bubba 95SN
Speed sensor on transmission spin and see what kind of AC voltage it produces.
Old Oct 29, 2010 | 11:00 AM
beamotorman205
Default no cruise control
does anybody know were the crusie control control module is located, and what the wireing diagram is,thanks
