Need Help!!
Need Help!!
I have problems with my car shutting off when cold. I will start just fine but once the fast idle goes down the car has a hard time idling and it will shut off. It seems like there is not enough fuel mixture because it won't fire back up unless I pump the gas a few times. I also have symptoms that include: idle surging, cutting out during acceleration, and stalling. Please Help!!!
Recent Mods: Fuel Pump, Ignition coil, carburetor, and muffler bearings..........j/k
RE: Need Help!!
I'm sorry forgot to mention it. It's a 1985 GT. It's too old for a code scanner isn't it? I did realize that there is no vacuum when the car is running for the hose that is connected to my vacuum advance. Do you think it is the EGR Valve? Thanx for the replies.
