Trick flow top end kit
I was looking at the trick flow top end kit and was wondering if you guys thought it was any good? It's about 2,200$, should i go for this, or just supercharge it? also, this might sound dumb but what all does the top end kit come with, i know it comes with heads and a cam but what else?
thanks
thanks
RE: Trick flow top end kit
i actually just started my engine tonight for the first time after installing that top end kit.......it fired right up
the kit includes heads (assembled), 1.6 roller rockers, intake (upper and lower), timing chain, pushrods, valve covers, hardware and maybe a few other small things
the instructions are kind of lacking on adjusting the valve lash ect. but overall a very well put together kit, looks great
one thing is that you have to drill your own hole in the valve covers for the oil filer tube which kinda sucked but was fairly easy
you also have to modify the egr a little for it to fit correctly, nothing that a hammer and a punch cant fix
