new engine.....rough idle
RE: new engine.....rough idle
yea its a stage I.
i looked at my tps and the articals ive read about adjusting it say you twist it until you reach the correct voltage but my tps cant be adjusted at all....its in a fixed location.
you probably know , but just in case you don't the 2 holes are bigger than the screws in the tps & allows for some movement when the screws are loose, some times the holes have to be enlarged slightly. i am running the tfs kit/ 24 lb. inj./65 tb/ 76 maf c&l cia, . it idles @ 750 like it is supposed to, but it took a little while for it to get used to all the new stuff . good luck.
Sounds to me like your MAF, the 5.0's will hardly run without it being just right and the only way to keep em running is to give them some gas. Is it calibrated for your injectors?
Set the timing to 14.
