vibration-flywheel?
RE: vibration-flywheel?
I was actually not the one that put the balancer on. The guy that did it said it went smooth. It seemed tight when I checked it out and it didn't wobble or anything. I checked the weight on the hb and it's still tight too. Is there anything else on the balencer I should look for? Could the flywheel be bent or warped?
ORIGINAL: ikeybmg
like tim says, it has to be either a loose balancer or damage to crank/thrust bearing from beating it on there or being rough with it.
lol..yea man im just throwing out some different thing that could be wrong. dont go wild on us yet. its unlikely you damaged the crank unless you was rough as heck putting it on. lol...i scared him tim
ORIGINAL: Tims 88GT
no no no, hold up chill for a second, it may be ok, do you have the stock balancer? if so put that on, lets not jump to fast here.
