rearend tire size
RE: rearend tire size
I've always heard that 295 is the biggest you can go without tubbing it out.
But this is hearsay, and not from experience. I did read an article once in MM & FF that said you can go all the way up to 315's with the 94 and ups, but the 87-93 hatches can handle 295 supposedly. The article also mentioned that hatches have a tiny bit more room than notches do. I don't know the reason for this or if it's true. Hope this helps.
I got a question. Whats the widest tire you can get to seal on an 8inch rim. Cause i got 8inch Draglites in the rear with 235r/60/15's and im wanting to put some mickey thompson slicks under the *** end of my car. I already took out my quads and rolled my fenders. So i got all the prep work done. Anybody know what it is though?
www.tirerack.com has charts that say what tires will fit on different size rims. just pick out a tire and then click on specs.
ORIGINAL: Hung Like a Stang
why do people run 40's in back and 45 in front?
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
M3hunter
09-05-2015 03:42 PM
09-01-2015 08:16 PM
