Grabbem & PRO50SC
RE: Grabbem & PRO50SC
ORIGINAL: Tims 88GT
Guys I wanted to say WOW and thanks. I clocked my maf and man did it make a diff in how the car ran, idled, and smells. Just wanted to say that and, to everyone else that may have idle problems you may want to clock your maf. This is where im at more towards the fender. It works perfect. This would mean it is richer? right?
[IMG]local://upfiles/11994/877CA70C4F674B03805380098A7132F8.jpg[/IMG]
As for the stock application, I doubt it will help out. It was designed the way it was built and that pretty much says it all.
Ben you can try it but I doubt you will have success. You need to try the things that have been suggested to you already and go from there.
ORIGINAL: 50mikey
See now I clocked mine in the same direction as PRO did, and it seemed to get rid of the hicups at cruising speeds.
ORIGINAL: PRO50SC
Each vehicle is different and will respond differently. NO 2 cars are alike.
ORIGINAL: 50mikey
just remember it might give you a too lean condition so make sure your fuel psi is in check..
i checked a couple of plugs today to make sure,and they were ok,but you'll just never know.
ORIGINAL: ZoSo15
so im guessing this is impossible on sn-95 because we our MAF bolts on to the intake tube. am i correct?
