advancing time 4 degrees
RE: advancing time 4 degrees
From what i've learned on here, If you advance to much you will Ping. So for instance if you go to 14* time, You might hear a pinging. In that case its to much, Or you just need to run a higher octane like 93. I'd set the timing for 12* because I think 10* is stock. Hope This helps.
^^ yea because i was going to say i ran 16 base with 5 degrees in cam so thats 21 all togeather, and it never pinged but my rpms hung up like a ****, so i knocked it down to 14 and so far its good.
Setting your base timing gives the eec a starting point to add to or take away from under different conditions dictated by your different engine sensor inputs. How much base advance you can safely set in depends alot on you engine combo and which octane fuel you run. Most can get away with 12, beyond that it depends a great deal on your engine, driving style and even where you live and the weather there....if you get deep into the details. Most play with it until they hear a "pinging" noise when they drive under load (heavy acceleration). This is detonation and left unchecked can be very destructive.
Back to your original question though setting your base timing is not like getting a chip, no matter what you set it to, it just changes the starting point for your eec so it is a straight-line change across the entire timing curve. A chip changes the table in whifch your eec adds or subtracts and is different throughout the curve and set to match driving conditions (from sensor inputs).
ORIGINAL: grabbem88
timing light/1/2 wrench..pull dis chip check timing. set it.tighten bolt recheck timing put chip back in.shut car off restart.
