Cam?
Cam?
All Right,I got a '85 gt,with a fairly new rebuilt motor,.30 over,any way I want to put another cam I have in mind the Comp Cam magnum,the specs are adv.dur.280, 512 lift the rpm range is 2000-6000.
My question is,is this to much lift for an almost stock engine?
My engine is not an HO,because I have the firing order of a regular 5.0, which is 1-5-4-2-6-3-7-8
Right now my car runs 15.1 thats my best time so far,I live in new mexico so the air sucks.
RE: Cam?
if you have a stock motor with e6 heads you're doing pretty good with a 15.1.
a cam won't do much at all for you at this point. you are much better off, putting in some gears, and other bolt ons.
RE: Cam?
Also I can get a port job by a local performance shop,he's well known at the track a lot of people recomend him for custum engines,any I call him the other day to get a quote,I told him what I do with the car,he told me he would charge 480-500 buck for a port job and do a vavle job also,he said he would put 2.02 chevy valve in it.so I think I might get the port job soon when I save up some cash.
RE: Cam?
Alright man that sounds good,I take your advice since you know what to do already thanks.
do you think that will get me down into the 14's?
Also recomend any gear companys?
RE: Cam?
ORIGINAL: ZachW04Stang
I'm not sure if the 85 mustangs had a 8.8 rear end. If it doesn't a whole rear end swap would have to be done. The 7.5's don't hold up well.
but to my knowledge from Ford they do not have the 8.8
