MAF and Crap
Old Mar 27, 2006 | 02:35 PM
8Ballz's Avatar
8Ballz
Default MAF and Crap
Hey is there any chance that if i do this clocking that the CEL will turn off??? Im starting to think that the dumbass mechanic i took it to put it on WAY wrong, so maybe thats why the car runs like crap.
And what is the best way to clean the MAF and IAC? I had a freind try to clean it with some sort of spray on his SC'ed BMW, and now the whole thing is destroyed. So i wanna make sure if there are any precautions...
1989 Mustang GT
3.27 FMS gears.
T-5 World class tranny.
SVO Clutch.
Moroso Cold air kit.
70mm EGR spacer.
70mm throttle body
pro-m 75mm
24 lb injectors.
GT40 upper and lower manifold.
E303 Svo camshaft.
1.72 SVO rockers.
HP Rods.
Trick Flow twisted wedges aluminum heads ported (stage1)
BBK chrome shorty headers.
off road H pipe.
Dynomax ultra flow welded mufflers.
3" tail pipes.
MSD 6al ignition poster.
Flex alite electric fan.
March pullies.
Summit elminating AC kit.
SVO spark plugs wires.
17" Cobra wheels.
Subframe Connectors.
_____________________________
'89 Mustang GT --- Around 420 Fly Horsepower
Yes, I am Palistinian. And no dumbass, im not a suicide bomber.
Old Mar 27, 2006 | 04:27 PM
gspfunk's Avatar
gspfunk
Default RE: MAF and Crap
Alcohol and a q-tip, but be very careful b/c that resistor will break easily. The MAF should have an arrow on it for direction of airflow so you can make sure it's on correctly.
Old Mar 27, 2006 | 05:00 PM
8Ballz's Avatar
8Ballz
Hey thanks man....
But did anyone clock there maf and have the Check Engine Light turn off??? Just checking
Old Mar 27, 2006 | 08:20 PM
ckyguy68's Avatar
ckyguy68
i dont think that would throw a MIL... all clocking does is slightly change the A/F ratio.
Old Mar 27, 2006 | 09:41 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: 8Ballz
Hey thanks man....
Have you had it scanned? That would be the best thing to do. Just guessing pisses you off worse!!
jwog666
Dec 27, 2021 08:09 PM
piotrek53
Oct 13, 2015 06:54 PM
mltdwn12
Sep 23, 2015 08:54 AM
stangin1996gt
Sep 21, 2015 11:01 AM
