BAAH! IDLE WENT APE SHIAT AGAIN..FIXED IT..FOR NOW HAH
RE: BAAH! IDLE WENT APE SHIAT AGAIN..
So it's searching for idle?? Do you have a hole in your TB plate? If not, try drilling a 1/4" hole in the center of one half of it.
EDIT: ...when it's off the car, of course...
no hole,and 1/4 is alot don't you think?..
ORIGINAL: gspfunk
Ok, let me get this straight. You clocked the meter, got it running right. But it has a cold start problem. You changed the clocking, now the idle search is back. Am I close?
yes exactly
ORIGINAL: PRO50SC
Hmmmm, ok, when the clocking was good for the idle, it was hard to start cold. By chance have you checked the cts for the ecm. Maybe it's sending hot start signal to the ecm when the engine is cold. Not enough fuel to fire it when cold. My wifes old explorer did that. It had the same symptoms you are describing.
