3.55/3.73s and traction
Old 03-29-2006, 06:09 PM
Twisted
Twisted's Avatar
Default 3.55/3.73s and traction
I am just getting ready to have some gears put in, although am undecided on which ones. At any rate, as it is, my car gets no traction at even half throttle in first gear--with the stock 2.73s. I know that this problem will be exacerbated greatly with 3.55s or 3.73s. I am currently running a set of 15X7 Centerlines (that I am looking to swap out at some point), and Dunlop G/T Qualifiers size P215/60R15. My two questions are:
1)What can I do to improve traction now, and particularly when I get the new gears?
2)Are these Dunlops a decent tire, and the correct size?
Thanks everyone.
Twisted is offline
Old 03-29-2006, 06:17 PM
89GTRed
89GTRed's Avatar
Default RE: 3.55/3.73s and traction
get some WIDER tires!
89GTRed is offline
Old 03-29-2006, 06:18 PM
89GTRed
89GTRed's Avatar
you know those are skinnier than stock right? stock is 225/60/15
89GTRed is offline
88BlueGT
88BlueGT's Avatar
One, go with the 3.73's. Get yourself a set of control arms... they will help alot.
88BlueGT is offline
Old 03-29-2006, 06:21 PM
Twisted
Twisted's Avatar
ORIGINAL: 89GTRed
Fair enough. Now do you mean wider tires, or wider rims and tires? If rims, what size rims will fit back there? I have been hesitant to get wider rims because the front of the car is lowered to some unknown height from stock. If I turn the wheel to the lock, I get a hint of rubbing. I'm not sure what will fit under there now. Any thoughts?
Twisted is offline
Old 03-29-2006, 06:22 PM
Twisted
Twisted's Avatar
ORIGINAL: 88BlueGT
Thanks for the reply, 88. Can you tell me a little about control arms? What do they do?
Twisted is offline
Old 03-29-2006, 06:24 PM
Tims 88GT
Tims 88GT's Avatar
no you need taller tires, wider helps but the hight make more diff that then width. and if you run a stock size tire you will have no traction in 1st and 2nd. if you have a good running motor.
Tims 88GT is offline
Old 03-29-2006, 06:26 PM
88BlueGT
88BlueGT's Avatar
ORIGINAL: Twisted
ORIGINAL: 88BlueGT
The best place to learn suspension if MaximumMotorsports.com
Check out their discriptions on their suspension pieces and it will explain why they are better than stock, other companies, etc. You will gain lots of general knowledge through this website.
88BlueGT is offline
Old 03-29-2006, 06:28 PM
89GTRed
89GTRed's Avatar
depends on what you want you could get some wider rims and put alot wider tires on there, but even with your rims i would think you could fit some 245's on there at least in the back. If you are worried about the front than dont make them any bigger, you are only peeling out in the back soo thats where you really need to widen them. Good LUCK man
89GTRed is offline
Old 03-29-2006, 06:38 PM
Twisted
Twisted's Avatar
ORIGINAL: 89GTRed
I DID NOT know that, Red. Thank you for the info. Now I really want new rims and tires.
Thanks for the link, 88.
Thanks for the info, Red. Good point about just changing the tires in the back. I will probably go that route. Any stability issues with doing that, or not really?
Twisted is offline
Quick Reply: 3.55/3.73s and traction
