Leaky Diff
Old Mar 4, 2004 | 02:31 AM
VertStangGT86's Avatar
VertStangGT86
Default Leaky Diff
My differential is leaking just a tiny bit out of the front/pinion end. It's next to nothing, it's taken a year or two to build up some crap on the inside, rear corners of my mufflers. Is there and easy way to fix it or do would I have to dissasemble the whole diff?
Old Mar 4, 2004 | 04:42 AM
n2o44's Avatar
n2o44
Default RE: Leaky Diff
you would have to remove the flange , carfullt using the right stuff , pull the seal out with the pinion still there , you will need a new crush sleeve, some people use the old one and tighten it just a lil more , but i wouldint. put the bearing back in, sleave , hit the seal in , reinstall the flange and nut , torque to the correct turning torque , basically that what you do .
Old Mar 4, 2004 | 05:27 PM
VertStangGT86
Cool, I'll have to look more into that for this summer when I start in on it. Got some surface rust to take car of on the door bottoms, inside of the fenders, and a couple other cosmetic things to take care of. I'll just have to start making a list now
67LimeCoupe
Sep 30, 2015 04:46 PM
Cavedawg
Sep 17, 2015 09:51 AM
Sep 1, 2015 08:16 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Shantymac
Feb 28, 2004 02:19 PM
