Rev limiter stock?
Rev limiter stock?
When I push the RPMs higher than 3800-3900 it sounds like theres a rev limiter on the car... (94 cobra) I don't know if there is a rev limiter or if valve float is happening that early or what. Anyone have an idea how to fix the rev limiter?
Thanks
Thanks
RE: Rev limiter stock?
What does a rev limiter sound like?
You could have a fuel delivery problem (clogged fuel filter)
Clogged air filter (if you can't remember the last time it was changed/cleaned, it's probably time to do it)
Clogged cats (pull the O2 sensors, if it pulls past 3900 you found your problem)
I guess that's enough to get you started.
