I'M SOO BUMBED OUT....see results....
i went today to get it tuned today......
i only made 308/332!!!!!!!!!
we played with timing/fuel....and that was the best it could do..
it only made power up to 5800k!and no this is not an APRIL FOOLS either..
my tuner said three things could be a factor with this..
1)cam timing is off...which i'm not sure cause i did what JAY ALLEN told me to do..
2)get a funnel web intake or a victor 5.0
3)or this cam is a blower cam?...
for some that don't know my cam is a .550/.533 229/239 @ 112.
RE: I'M SOO BUMBED OUT....see results....
dss pro bullet 306
afr 185's
all msd
24's
rpm/w spacer
dss 1.6's
accufab 70mm
pro-m 75mm
you want more?...if so ask away.
afr 185's
all msd
24's
rpm/w spacer
dss 1.6's
accufab 70mm
pro-m 75mm
ORIGINAL: PRO50SC
What exactly is your combo?
Can you give us the specs? Cubes, heads? flat or roller cam? Intake? Carb size? Auto or stick? Chassis dyno? Give the full meal deal and this may help to find where you should be at or if there is room to improve.
i posted most of it besides mac L/T's..off rd x-pipe..flows dumped.
compression is 9.7 ...oh tko 5spd...dynojet
ORIGINAL: wildcobrar
