Got quoted today for a cam install...
RE: Got quoted today for a cam install...
Quoted for what? Cam?
Most performance shops charge $100 an hour at least where I live.
-Edit-
Oops didnt read title, 300 sounds about right for a Cam job. Takes about 3 hours for a good mechanic.
They need to take the lower and upper intake off, fuel rails, rockers, timing cover, water pump, some pulleys and then replace all the gaskets and seals.
-Edit-
Remember guys that you NEED to change out the valve springs when you do a cam swap. If you don't you will not see much of a gain with new cam and you might cause damage due to coil bind and/or valve float.
ORIGINAL: JD1969
