valve cover torque
#21
RE: valve cover torque
Check your plug wires. Maybe you bumped one loose while changing the covers. Unless you messed with the valve seals you shouldn't have a sudden oil leaking problem. It is probably something easy like a wire. Did you replace your upper intake gasket when you had it off? Mess with the fuel injectors at all?
#22
nope
ORIGINAL: 5.0stanger
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
