what are the best heads i can use
Old Apr 6, 2006 | 02:07 PM
91stang's Avatar
91stang
Default RE: what are the best heads i can use
the canfeild heads shown were 192cc's and it flowed better than 185 and 165... but it's bigger
90Mustangfan's Avatar
90Mustangfan
I ♥ Acer
yup and those yates heads are better flowing, they are nascar heads and they flow alot at .700 lift, you can find those heads and intake on ebay, but they are better than afrs.
Old Apr 6, 2006 | 02:13 PM
91stang's Avatar
91stang
ah ha.. found it
http://www.allfordmustangs.com//Detailed/630.shtml
LESNOVR's Avatar
LESNOVR
HAVE TO KEEP IN MIND WHAT YOUR ARE PLANING TO DO. A CAM WITH .700 LIFT WILL NOT BE VERY STREETABLE. AND IF YOU ARE PUTTING A VERY GOOD FLOWING HEAD ON YOU WILL NEED TO UPGRADE EVERYTHING. FOR A STOCK MOTOR JUST LOOKING FOR EXTRA HP I WOULD GO AFR OR TWISTED WEDGE. I HAVE STAGE 1 PORTED TWISTED WEDGE ON A 331. THEY FLOWED 309 AT ONLY .600 LIFT. AT .600 LIFT MY CAR IS STILL VERY STREETABLE AND MY CAM IS STILL HYDRAULIC ROLLER.
ALL DEPENDS ON WHAT YOU ARE WILLING TO SPEND.
Old Apr 6, 2006 | 02:15 PM
primetime5.0's Avatar
primetime5.0
does anybody run Trick Flow High Ports anymore?
88BlueGT's Avatar
88BlueGT
^^^ Very true.
Old Apr 6, 2006 | 02:20 PM
LESNOVR's Avatar
LESNOVR
I DONT EVEN KNOW IF YOU CAN GET THEM ANYMORE. AND AS FAR AS CLEARANCE ON THE HEADS , I HAVE REVERSE DOME AND NOTCHED PISTONS, MY MOTOR IS BUILT FOR SPRAY OR BOOST, SO MY COMPRESSION IS ONLY 9-1. I RUN NA FOR DURABILITY REASONS AND MY MOTOR STILL MADE 440hp. I WOULD BUY ANOTHER DSS SHORT BLOCK IN A HEARTBEAT. THEY ARE SECOND TO NONE IN MY OPINION
Old Apr 6, 2006 | 02:22 PM
primetime5.0
High Ports are still available as for as my knowledge goes, but i wouldnt buy anything from DSS just my opinion
Old Apr 6, 2006 | 02:23 PM
LESNOVR's Avatar
LESNOVR
WHY NOT ? Just curious?
Old Apr 6, 2006 | 02:27 PM
gspfunk's Avatar
gspfunk
ORIGINAL: primetime5.0
Why not?? You know you can't just say that and not back it up.
