Explorer Rear Calipers
Old Apr 7, 2006 | 03:45 PM
mustangdave357's Avatar
mustangdave357
Default Explorer Rear Calipers
Hello all, I am using a ford motorsport rear disc brake conversion kit for a ford 9" rear end and the kit is based off of a 1996 ford explorer. I have everything installed but I think I have a problem. I have brake fluid seeping from the fitting that screws into the explorer brake hose. Everything is tight and secure but my master cylinder keeps going empty for the rear portion. My mustang is a 1984 and has traditional brake line flare. Someone told me that the ford explorer of that time period uses a bubble flare in the brake hose. They said I needed a 3/16-m10x1.0 adapter to go from regular flare to bubble flare. Is this possible? Does the explorer brake hose use the bubble flare?
Thanks in advance, Dave
Old Apr 7, 2006 | 04:38 PM
BraMas's Avatar
BraMas
Default RE: Explorer Rear Calipers
Did you replace the brass washer's on the line that bolts into the caliper's?
Old Apr 7, 2006 | 05:00 PM
mustangdave357
Yes, I replaced them and when I noticed they were leaking I replaced them again thinking that was my problem. I have normal flare going into the brake hoses and if someone could tell me what flare is on the explorer brake hose I might be able torule out that, thanks for the thought though
Old Apr 7, 2006 | 07:30 PM
BraMas's Avatar
BraMas
I guess your gonna have to use duct tape then. Try calling Ford racing or maybe check out there website www.fordracingparts.com. They can point you in the right direction. I'm assuming there the ones that sold the kit to you in the first place.
69Volunteer
Sep 30, 2015 10:39 AM
mdj89
Sep 23, 2015 08:49 AM
maestro1024
Sep 21, 2015 02:40 PM
Sep 16, 2015 07:53 PM
Sep 1, 2015 08:16 PM
