How hard is it too...
RE: How hard is it too...
First make sure the rear brakes are adjusted correctly. The adjustment for the e-brake is on the handle itself. Look down in where it goes into the console and you should see a threaded rod w/ a nut on it. That's how you adjust it. Turn the nut clockwise to tighten it.
Well since you brang it up, I just replaced my shoes on my drums (eww drums) and that adjustment behind the drum I wasn't sure what to set it to, so I just kept tightening it until I couldn't put on the drum, then backed it off. Thanks for all your help btw PRO50SC.
Matt's 95 Stang
10-05-2015 07:16 AM
