Help Me
Help Me
ok so i was driving my mustang around and when i poped the clutch it would lay like a 5 inch patch then bog and then the next day it wudnt idle i had to hold the gas at like 1000rpms for it not to stall and black smkoe was comin out of the exhaust and it felt like it had lost power when i drove it around any idea whats wrojng with it?
RE: Help Me
ORIGINAL: 1990mustanglx
What do u think could be wrong with it? whats black smoke mean again coming from the exhaust pipes
RE: Help Me
If your O2 sensor is giving bad readings, it could be causing your computer to overcompensate rich. You are definitly running rich, so you have to figure out why. Try replacing the O2 sensors (replace both of them, no sense just doing one) and see if that helps. If not, you will have to take it to someone to diagnose your problem for you. Good luck.
RE: Help Me
ORIGINAL: roughneck9725
