OVERHEATING
Old Apr 10, 2006 | 06:54 PM
MUSTANG91's Avatar
MUSTANG91
Default OVERHEATING
I PUT A TRICKFLOW INTAKE IN MY CAR AND NOW IM GOING SLOWER CAR IS STOCK AND IS NOW OVER HEATING ALL THE TIME
Old Apr 10, 2006 | 06:55 PM
88BlueGT's Avatar
88BlueGT
Default RE: INTAKE OVERHEATING
The car is overheating or the manifold is overheating? LoL Im confused......
Old Apr 10, 2006 | 06:56 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: MUSTANG91
Sounds like you have either a coolant blockage (coolant is not circulating through the intake) or if notice your coolant levels running low or smoke out the back, that would be a leak
Old Apr 10, 2006 | 06:58 PM
MUSTANG91's Avatar
MUSTANG91
THE CAR IS OVER HEATING.
Old Apr 10, 2006 | 07:00 PM
MUSTANG91's Avatar
MUSTANG91
HAD THE INGINE FLUSHED WATER FLOWS ALL RIGHT
Old Apr 10, 2006 | 07:04 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: MUSTANG91
Please turn the CAPS, OFF
water was flushed through before or after the install? With or without the thermostat in it?
Old Apr 10, 2006 | 07:07 PM
MUSTANG91's Avatar
MUSTANG91
flush was done after intalation at a shop dont know
Old Apr 10, 2006 | 07:10 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: MUSTANG91
well if they did a flush then it was without the thermostat. Only guess I have is that the thermostate was put in backwards. Was it overheating before the flush? If not, that's probably the problem. If it was, then you may have a blockage somewhere. A piece of gasket or junk could've gotten stuck in a head somewhere when you were replacing the intake. Oil level look okay? Does your oil look 'milky'?
Old Apr 10, 2006 | 07:16 PM
MUSTANG91's Avatar
MUSTANG91
i will open it up and check.oil level look ok clean
Old Apr 10, 2006 | 07:23 PM
MUSTANG91's Avatar
MUSTANG91
do you have an idea why im going slower.
